Hello!
I am attaching a photograph of my mog’s front panel.
I saw different front panels. Is it possible anyone confirm which picture is according to the original front panel of the unimog 411.119?
Besides this, I have doubts about the original distribution (position) of the different parts (red/blue/green indicators, temperature gauge, speedometer, etc.)?
Thanks in advance,
Alex
Front Panel 411.119.jpg (66.34 KiB) 832 mal betrachtet
#191786
Hi,
the front panel is equipped according to the features of your 411.119. The standard is a speed meter on the right hand. followed by the temperature gauge and a double air pressure gauge. A revolution meter was a seldom option. Below this row on the left there could be a fuel gauge as option, later years standard as well. On the very right bottom there is the switch for the direction indicators with a red lamp on top. Left hand there is the glow indicator and the start button. Close to are three lights, hi beam control in blue, oil pressure in green and red for generator. Below are the start key switch.
Hallo Jan , frage mal bei dem Unimog Team Fitzen a[…]
VDO Öldruckanzeige Nadelstreifen - 60mm Einba[…]
Hallo, das ist ein altbekanntes Spiel um die Vers[…]
Hallo Zusammen, ich habe mir einen Unimog zugele[…]
