Hello, I\'m still here,
A friend of mine has 2 unimog axles (front and rear), he told me that they were mounted on a 411 and now he has to change some spare parts. He asked me help because he hasn\'t the chassis number of the truck in order to buy parts by MB, I gave the chassis number of my 411 but MB of his zone I think hasn\'t the list of spare parts of 411, so I gave the chassis number of a 421 but nothing.
On the differential (front) he found this numbers:
403 351 02 03 on the diff case
406 351 0315 1125-52 on the main shaft (I don\'t know what\'s the english of this part, it\'s the tube that contain the drift shaft)
Is this a 411 axle? or ??
Please help me!!
Contact me by mail please, so I\'ll give you an image of the parts that he needs
Unimog Forever
Matteo
#30266
Die beiden Nummern sind keine Ersatzteilnummern von DC. Ich vermute mal das es Rohteilnummern sind. Ich denke aber das es sich bei den Achsen um 3-teilige 411er Achsen handelt. Die Teilenummer des Mittelgehäuses bei den 3-teiligen Achsen ist 406 351 0203. Könnte auch sein das sich teounimog verlesen hatte mit den 403.
Hello Matteo,
if you tell me your faxnr. I could send you some pictures from the sparepart-list of the axle that I think your friend have.
Grüße von Manfred
Guten Morgen Stefan Ich habe hier noch ein &qu[…]
Knopf unter Kupplungspedal
