#576694
Hello
in German, they are called Schlepphebel.
So you can find some offers, for example
Schlepphebel 1140550001
6x Schlepphebel
#579371
Danke Helmut,
Strange, I never end up on this site...and I browse a lot. I checked the thermostat too, it behaves strange. Opens at 80-90 deg, but start to close at 40 deg , this is quite a big hysteresis , which maybe explains, why my Mog don\t want to heat up upon 40-50 deg.
I'm divided on new project opportunity, should I
-covert to electric fan
-rework water system hoses and thermostat
-relocate expansion tank...
I really don't like the current setup, where water expansion tank is next to you face in the cabin. I know in the 50's, safety was not think , but....
...anyway the people back than were way cooler and crazier
#579642
Hello,
Slowly I work out to my plan. Till now I was able to adapt thermostat body of OM 615...2.4D and now I'm working to convert to all accessories (water pump and alternator) to mehrspurig Gurt. Unfortunately I can't find a place for hydraulic power steering pump...I start to consider EPS from car...it will be more easier...I think...but often I'm wrong :D
unimog belts.jpg (263.11 KiB) 2606 mal betrachtet
unimog belts 2.jpg (257.9 KiB) 2606 mal betrachtet
  • 4
  • 5
  • 6
  • 7
  • 8
Anhängekupplung 411.119
