#579656
Hello Leute,
I aways want to to do thinks with old parts (save the planet and recycle), so for the crank pulley I try to use an old Audi failed damper crank . I've made central hub from Alu and plan to hot press the Audi pulley. I heat the pulley at 250 deg (there was 0,15 mm oversize diameter on hub)...and it didn't press to the end, so I hammer it well...and the pulley cracked :evil: :evil: :evil: :evil:
So good bay Mehrspurig Gurt and back to the classic Gurt. And in the process I hammer my finger well too.
  • 4
  • 5
  • 6
  • 7
  • 8
Hallo Mogler, nach einer Totalrestauration von mei[…]
gaspedal Lagerung im 406121
Und die Zugstange muss in der richtigen Bohrung mo[…]
