#583384
Hi,
The term
"Saginaw pump" likely refers to the secondary air injection pump (also known as an A.I.R. pump or "smog pump") used in the exhaust emission control system of the Mercedes-Benz Model 280S/8. Saginaw is a common manufacturer of such pumps, particularly for vehicles from that era.
The function of this pump is to reduce harmful emissions (specifically unburned hydrocarbons and carbon monoxide) during a cold start.
Role in the Emission Control System
Air Injection: During the engine's warm-up phase, which typically involves a rich air-fuel mixture to ensure smooth operation, the air pump draws in ambient air and injects it into the exhaust manifold, downstream of the exhaust valves.
Oxidation (Afterburning): The added oxygen in the exhaust stream causes a secondary burn (oxidation) of the unburned fuel and carbon monoxide, converting them into less harmful carbon dioxide and water.
Catalytic Converter Efficiency: The heat generated by this afterburning process helps the catalytic converter reach its optimal operating temperature faster, allowing it to work efficiently sooner.
The pump typically only runs for a short period (around 2-3 minutes) after a cold engine start, after which it is shut off by the engine control unit. While the pump is not essential for the engine to run, it is a critical component for meeting emissions standards.
best regards Götz
#583392
Hallo Robert
berti1554 hat geschrieben:. Sieht so aus als ob die nur fuer USA Modelle verbaut wurde.
das war wahrscheinlich aus einen Fahrzeug mit der California-Emissionsbegrenzung.
Der Motor lief überall auf der Welt auch ohne.
Guten Morgen Helmut Danke für deinen Input. D[…]
Fenstergriff Cabrio ersetzen
Hallo Wolfgang, ich habe bei mir den komletten He[…]
Erster Unimog und direkt eine Großbaustelle
Hallo Alexander die Schrauben an den Kurbelwellen[…]
Hallo Martin, kann du mir Bilder mailen. Info@thie[…]
